NEC 22" Multisync EA223WM Black LED 1690 x 1050 DVI Monitor
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8H1NWS00 Mfr#: 60003294
NEC MultiSync EA223WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient light and human sensors enforce the sustainable product concept while offering improved ergonomics with 130mm height adjustability. Moreover the display offers broad connectivity with three inputs DisplayPort, DVID and D-Sub.
Ideal for the corporate that demand style and future proof technology.
  • Ambient light sensor
    With auto brightness function always sets optimized brightness level according to ambient light and content conditions.
  • Ergonomic office
    Full height adjustability (130mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic setup.
  • Feature set for perfect office use
    Integrated speakers, headphone jack and USB hub provide excellent options for office communication.
  • Green product concept
    Eco mode and carbon footprint meter/carbon savings meter, ambient light sensor.
  • Human sensor
    Detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
  • Image display
    22-inch 16:10 TN with LED backlight.
  • VESA mount (100mm)
    Allows to install the monitor via various mounting solutions.
NEC MultiSync EA223WM - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
18 kWh
Power Consumption (On mode)
12 W
Stereo speakers, USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
HD 720p 1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
50.4 cm x 21.8 cm x 38.4 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA
3-year warranty
Display Type
Energy Class
Class A
18 kWh
Diagonal Size
22"
Built-in Devices
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
82.3 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, Eco-Mode, ControlSync
50.4 cm x 21.8 cm x 38.4 cm - with stand
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , 4 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Audio line-in
Mechanical
Tilt Angle
35
Swivel Angle
240
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x USB cable , 1 x DisplayPort cable , 1 x ControlSync cable
Power Supply
Internal
12 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
