- Mustek ScanExpress A3 USB 600 Pro - flatbed scanner - desktop - USB
- Flatbed scanner - desktop
- Interface Type
- USB
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 1200 dpi
- Interpolated Resolution
- 9600 dpi x 9600 dpi
- Max Document Size
- 297 mm x 420 mm
- Supported Document Type
- Plain paper, bulk objects (such as books, magazines and other bound materials)
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- 38.4 cm x 56.3 cm x 8.7 cm
- 4.3 kg
- Interface Type
- USB
- A3 (297 x 420 mm)
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- Scan Mode
- Single-pass
Media Handling
- Max Document Size
- 297 mm x 420 mm
- Manual
- Interfaces Details
- USB - Type B
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Device
- External power adapter
- Power Consumption Operational (Standby)
- 20 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 38.4 cm
- 56.3 cm
- 8.7 cm
- 4.3 kg
