The ScanExpress A3USB 2400 Pro from Mustek is the newest tabloid size scanner from Mustek. The scanning resolution is 2400 x 2400 which will give you beautiful in depth quality of documents and photos.
- Mustek ScanExpress A3 USB 2400 Pro - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 2400 dpi x 2400 dpi
- Interpolated Resolution
- 9600 dpi x 9600 dpi
- Max Document Size
- 297 mm x 420 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4 - 10.6
- 38.3 cm x 55.5 cm x 8.8 cm
- 4.3 kg
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
Media Handling
- Max Document Size
- 297 mm x 420 mm
- Plain paper
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 20 Watt
- Software Included
- Drivers & Utilities, Adobe Acrobat Reader, ABBYY FineReader, ArcSoft MediaImpression
- OS Required
- 38.3 cm
- 55.5 cm
- 8.8 cm
- 4.3 kg
