If you're looking for a step up in resolution while retaining the ability to reach blazing fast refresh rates, a 1440p 175Hz 16:9 monitor like the MPG321QRF-QD might be the one for you.
The rapid IPS panel on this monitor grants you the color accuracy and vibrancy of colors gamers associate with a high-quality IPS panel. What's more, it also gives you excellent viewing angles of up to 178-degrees (both vertical and horizontal).
Although higher resolutions do offer a better gaming experience, they invariably come at the cost of performance if you don't have the hardware to feed them. That's precisely why the combination of a blazing-fast refresh rate and a 2560x1440 (1440p/WQHD) resolution is ideal for most gamers.
The 1440p resolution packs in a whopping 78% more pixels than a regular 1080p (Full HD) monitor. Games will not only look crisper, but you'll be able to see so much more of the beautiful game world at a time. For competitive players, this allows them to see and react to much more information about their surroundings.
A 175Hz refresh rate brings the smoothness and fluidity you need when you're playing fast-paced games. Every quick enemy movement will feel smoother, and you'll be much more accurate with your shots, even at long distances.
KVM switches allow you to control multiple devices with the same keyboard, mouse, and monitor. If you're streaming and have a second PC or often use a work laptop, the built-in KVM switch on the MPG321QRF will make your life so much easier.
- MSI Optix MPG321QRF-QD - LED monitor - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Adaptive-Sync Technology
- NVIDIA G-SYNC Compatible
- 5-way joystick, USB 3.2 Gen 1/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 (DisplayPort: 175 Hz, HDMI: 144 Hz)
- Pixel Pitch
- 0.27675 mm
- Brightness
- 600 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- HDR Capable
- DisplayHDR 600
- Response Time
- 1 ms (MPRT)
- Gaming
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 95% DCI-P3 (CIE 1976), 144% sRGB (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 72.7 cm x 25.1 cm x 48.2 cm
- 10.2 kg
- CIE1976, DisplayPort 1.4a
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.2 Gen 1/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27675 mm
- Brightness
- 600 cd/m²
- Contrast Ratio
- HDR Certification
- DisplayHDR 600
- Colour Support
- Colour Gamut
- Response Time
- 1 ms (MPRT)
- Vertical Refresh Rate
- 48 - 175 Hz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Picture in picture, picture by picture, frameless, Flicker Free technology, MSI Anti-Flicker, Quantum Dot Technology, Low Blue Light technology, night vision mode, MSI Mystic Light, 10-bit(8-bit + FRC) Colour Depth, Rapid Boost, mouse bungee
- Black
- 10.2 kg
Input
- 5-way joystick
- DisplayPort 1.4a , 2 x HDMI , Microphone , Headphones , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 upstream/DisplayPort Alt Mode (KVM option)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 40.9 kWh/1000h
- Power Consumption HDR (On mode)
- 95 kWh/1000h
- Power Consumption (Typical)
- 42 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Shipping Width
- 97.5 cm
- Shipping Depth
- 18.1 cm
- Shipping Height
- 55 cm
- Shipping Weight
- 13.9 kg
