- LG MyView 27SR50F-W - LED monitor - Full HD (1080p) - 27" - HDR
- LED-backlit LCD monitor - 27" - Smart monitor
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1701992
- Energy Class
- Class E
- Bluetooth adapter, USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- HDR10
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- 2xHDMI
- Tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- 61.18 cm x 20.99 cm x 45.09 cm
- 5.6 kg
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class E
- Energy Class (HDR)
- Class F
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- Response Time
- 14 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- 8-bit(6-bit + FRC) Colour Depth, Flicker Safe, Auto Brightness Control, Smart Energy Saving technology, Screen Share, AI concierge, Dashboard
- 61.18 cm x 20.99 cm x 45.09 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI , 2 x USB downstream
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), AirPlay 2
- Included Accessories
- Remote control
- Cables Included
- 1 x HDMI cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption HDR (On mode)
- 24 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- Included Software
- ThinQ Home, WebOS 23
- Dimensions & Weight Details
- With stand - width: 61.18 cm - depth: 20.99 cm - height: 45.09 cm - weight: 5.6 kg , Without stand - width: 61.18 cm - depth: 4.51 cm - height: 37.09 cm - weight: 4.4 kg
- Shipping Width
- 76.8 cm
- Shipping Depth
- 12.6 cm
- Shipping Height
- 43.5 cm
- Shipping Weight
- 7.3 kg
