Motorola AP-7522 Indoor 802.11AC
Quicklinx: DD2DWS00 Mfr#: AP-7522-67040-WR
  • IEEE 802.11n
This versatile dual radio access point can operate as an in-line sensor for client location awareness and security threat analysis or can be used as a dedicated full-time dual band sensor - an ideal tool when building a multi-role, secure network. The versatility of the AP 7522 also means cost savings without sacrificing quality.
  • Comprehensive features serve as a multi-role network access point
    This wireless LAN access point includes 2x2 MIMO, 2-spatial streams, as well as 256 QAM modulation that boosts the bandwidth of the 802.11n radio up to 802.11ac levels, with support on both the 2.4 GHz and 5 GHz band. To meet sensor requirements, deploy a single AP 7522 as a dedicated sensor for high-demand use, or use a single AP 7522 as a sensor and an access point to get the most usability out of your network. Given the high-powered antenna and radio capability, you'll need fewer access points while enjoying enhanced gap-free security features. Security enhancements also include radio share and off-channel scan, which provide a great deal of flexibility when the AP 7522 is acting as an access point and a sensor simultaneously.
  • Antenna designed to bring reception to the outer edge
    The symmetrical internal antenna design of the AP 7522 pulls RF power to the edge of each unit's range rather than concentrating it in the middle. This makes network design easier for architects, and delivers a better user experience for wireless clients at your facilities.
  • Easy and cost-effective movement to 5th gen WLAN standards
    Dual radio capability provides an easy upgrade path to next gen WLAN, delivering performance and capacity to meet the demands of voice, data, and video while continuing to deliver support for Wi-Fi client devices on 2.4 GHz and 5GHz frequencies.
Extreme Networks AP 7522 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
16.5 cm x 18 cm x 4.1 cm
820 g
Radio access point
16.5 cm
18 cm
4.1 cm
820 g
External
Wireless
Data Transfer Rate
1.267 Gbps
Line Coding Format
256 QAM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
PPPoE, BOOTP, DHCP, DDNS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Routing, auto-sensing per device, NAT support, power over Ethernet (PoE), VPN support, BOOTP support, load balancing, dynamic DNS server, DiffServ support, IP address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, roaming function, DHCP server, 2T2R MIMO technology, LLDP support, Stateful Packet Inspection Firewall (SPIF), Low Density Parity Check (LDPC), DHCP client, Space Time Blocking Code (STBC), ceiling mountable, 8KV/15KV ESD Protector, Type of Service (ToS)
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 2 x aerial - RP-SMA , 1 x console - RJ-45
UL 2043, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, TELEC, cUL No.60950-1
PoE
OS Provided
WiNG 5
-20 °C
0 - 85% (non-condensing)
