Mophie Powerstation XXL - Universal Quick Charge External Battery
Quicklinx: DL6LWS00 Mfr#: 3565_PWRSTION-XXL-20K-SGRY
Talk, play and browse longer than ever with the new mophie powerstation XXL universal battery. This 20,000mAh universal battery is packed with more power then ever. Get more than seven additional charges on your smartphone or get up to two extra charges on your tablet. Three USB ports let you charge multiple devices. The compact design and premium aluminum finish make this model easy to carry.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
  • Three USB charging ports
    With enough battery to extend your smartphone's battery life, this high-capacity battery pack is also designed for users who need to power multiple devices.
  • High-output charging
    Smart adaptive charging technology identifies your connected device and always delivers a safe and efficient quick charge.
  • Aluminum finish
    High-performance power concealed inside a sophisticated and sleek design make this the perfect accessory for any professional lifestyle.
mophie powerstation XXL power bank - USB
Power bank
9.2 cm x 2 cm x 15.5 cm
428 g
Space grey
Output Connector Type
Total 3: USB - on cable: Micro-USB
Max Electric Current
2.1 A
20000 mAh
Power Device Details
2 x - 4 pin USB Type A - 2.1 A , - 4 pin USB Type A - 1 A
Cables
Micro-USB cable
Power bank
9.2 cm
2 cm
15.5 cm
428 g
Enclosure Colour
Space grey
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Total 3: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2.1 A
2 x 4 pin USB Type A - 2.1 A , 4 pin USB Type A - 1 A
Temperature protection, short circuit protection, overcharging protection, power LED Indicator
20000 mAh
Material
Aluminium
Micro-USB cable
