Talk, play and browse longer than ever with the new mophie powerstation XL universal battery. This 10,000mAh universal battery is packed with more power than ever. Get more than three additional charges on your smartphone. Two USB ports let you charge multiple devices.
Dual USB charging ports
With enough battery to recharge a smartphone up to three times, this powerstation battery is also designed for users who need to power multiple devices or simultaneously charge two tablets. -
Priority+ charging
Enables pass-through charging while connected to a power source. Your device recharges first, and then the powerstation battery recharges itself. -
High-output charging
2.1A output and smart adaptive charging technology identify your connected device and always deliver the fastest, most efficient charging speeds available. -
Aluminum finish
High-performance power concealed inside a sophisticated and sleek design make this the perfect accessory for any mobile lifestyle.
- mophie powerstation XL power bank - Li-pol - USB
- Product Type
- Power bank
- 6.92 cm x 1.59 cm x 13.2 cm
- 218 g
- Space grey
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Max Electric Current
- 2.1 A
- Battery
- Lithium polymer - 10000 mAh
- Cables
- Micro-USB cable - 22.9 cm
- 2-year warranty
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 6.92 cm
- 1.59 cm
- 13.2 cm
- 218 g
- Enclosure Colour
- Space grey
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- Power LED Indicator
- Technology
- Lithium polymer
- Capacity
- 10000 mAh
- Material
- Aluminium
- Cables Included
- FCC, RoHS
- Limited warranty - 2 years
