Never carry a charging cable again. The mophie powerstation plus XL universal battery combines a compact design, premium feel and built-in switch-tip charging cable that charges both Apple and micro USB devices. This 12,000mAh battery gives you more than four additional charges on your smartphone or one extra charge for your tablet. A second USB port lets you charge two devices at the same time. Charging on-the-go is now easier than ever.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
Dynamic power & convenience
These low-profile universal batteries feature an elegant design and a built-in switch-tip charging cable with micro-USB and Lightning connectors for added convenience. -
Power beyond boundaries
High-capacity battery delivers many hours giving you the power to do more. -
Know before you go
Push the integrated power indicator button to display the charging status and current battery life of your powerstation. Know before you go. -
Compact design
The Powerstation Plus is thinner than previous generations. The improved hide away cable features a switch-tip design that eliminates the need for additional cables, giving you even greater portability.
- mophie Powerstation Plus XL power bank - USB
- Product Type
- Power bank
- 7.94 cm x 15.48 cm x 1.68 cm
- 275 g
- Space grey
- Output Connector Type
- Total 2: USB - on cable: Micro-USB, Lightning
- Max Electric Current
- 2.1 A
- Battery
- 12000 mAh
- Cables
- Micro-USB cable - 22.9 cm , Lightning to micro-USB adapter
- 2-year warranty
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 7.94 cm
- 15.48 cm
- 1.68 cm
- 275 g
- Enclosure Colour
- Space grey
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B, Lightning
- 2.1 A
- LED indicator
- Capacity
- 12000 mAh
- Battery level indicator
- Cables Included
- Limited warranty - 2 years
