Cables, Power & Adaptors
Surge Protection
Monster High Definition PowerCenter™ v2 w/ GreenPower™ - 7 Way
Belkin 6 Way Surge Protection Strip - 2m with 2 x 2.4 amp...
Belkin 8 Way Surge Protection Strip - 2m with 2 x 2.4amp USB...
Cables Direct 3Mtr 6 Gang UK Switched Power Block + Surge...
Lindy 1U 6 Way UK Sockets Horizontal PDU with IEC C14 Cable...
Cables Direct 2MTR 4 Gang UK Switched Power Block + Surge
Belkin Connect Surge Protector with USB-C and USB-A Ports
