The APC SurgeArrest Essential series represents the minimum level of surge protection that should be present on any of your computers and household electronics, with most models also providing surge protection for your phone lines. Its state of the art circuitry offers protection for sensitive electronic equipment against larger power surges and multiple surge events.
Protection Working Indicator
SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge -
IEEE let-through ratings and regulatory agency compliance
APC surge protectors undergo stringent testing by IEEE, and are awarded "let-through ratings", which indicate the maximum voltage level that can possibly reach your equipment after a surge or voltage spike has passed through an electric surge protector. Lower IEEE let-through ratings indicate better protection and performance. The APC Essential SurgeArrest series offers optimal performance with a let-through rating of less than 330V to 500V for North American products, and a rating of less than 15% for products sold worldwide. All APC products comply with local agency safety requirements, including UL in North America and CE/Kema/Gost/C-tick/A-Tick/Telepermit in their respective regions -
Data-line Protection
Protection of data lines (Ethernet, Coaxial and Phone lines) ensures complete protection of your equipment from surges. It is very important to protect your equipment from “back door” electric surges traveling through data lines, as they can be as damaging to your equipment as surges traveling over power lines -
EMI and RFI noise filtering
Reduces line noise that can cause data loss and keyboard errors
- APC SurgeArrest Essential - surge protector
- Surge protector - external
- 690 g
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Connectors
- 1 x power BS 1363A
- Output connectors
- 5 x power BS 1363
- White
- 38.5 cm x 7.3 cm x 5.6 cm
- Limited lifetime warranty
- White
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 50 Hz
- Input Connectors
- Power Output Connectors Details
- 5 x power BS 1363
- Max Electric Current
- 13 A
- Dataline Surge Protection
- Phone line - RJ-11 - 1 input line / 1 output line
- Surge Suppression
- Surge Energy Rating
- 918 joules
- EMI/RFI Noise Filtration
- 40 dB
- Max Spike Current
- 24000 A
- Circuit Protection
- Circuit breaker
- Cables Included
- Power cable - integrated - 1.83 m
- Equipment Protection Value
- 50000 Euros
- LED indicators
- RoHS, REACH
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 90%
- 38.5 cm
- 7.3 cm
- 5.6 cm
- 690 g
- Shipping Width
- 40.5 cm
- Shipping Depth
- 13 cm
- Shipping Height
- 5.8 cm
- Shipping Weight
- 800 g
