The Surface USB to Ethernet adapter connects your surface pro to a network when Wi-Fi is not available.
- Microsoft Surface USB to Ethernet adapter - network adapter - USB - 10/100 Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- 10/100 Ethernet
- 2.2 cm x 1.7 cm
- Length
- 30.5 cm
- 24 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- 1-year warranty
- Designed For
- Surface Pro, Pro 2
- Network adapter
- Form Factor
- External
- USB
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 1 x 100Base-TX - RJ-45
- 2.2 cm
- 1.7 cm
- Length
- 30.5 cm
- 24 g
- Limited warranty - 1 year
- Designed For
- Microsoft Surface Pro, Pro 2
