StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter
Quicklinx: FLW4WS00 Mfr#: CDP2DP14B
29 In Stock
£20.32 ex VAT
£24.38 inc VAT
This USB-C to DisplayPort adapter lets you connect your USB Type-C or Thunderbolt 3 device to a DisplayPort monitor or display, providing you with a convenient, high-performance solution. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography; Streaming high-resolution, life-like content.
The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
This lightweight display adapter is highly portable, with a small-footprint design. It's the perfect accessory for your MacBook, Microsoft Surface Book or other USB-C (or Thunderbolt 3) device, fitting perfectly into your carrying case.
To ensure easy operation, this USB C to DisplayPort adapter supports plug-and-play installation, removing the need for additional software or drivers.
Your USB-C device must support DP Alt Mode to work with this adapter. This product will not work with the Samsung S8 smartphone. For hassle-free compatibility with the S8 use CDP2DP.
  • Incredible 8K Picture Quality
    Supporting four times the resolution of 4K, this 8K DisplayPort 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320; and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging. With cutting-edge picture quality, this adapter is ideal for: • Displaying crisp digital signage walls • Creating eye-catching visuals for photography and videography • Streaming high-resolution, life-like content The DisplayPort dongle is also backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
  • Ideal for Travel
  • Hassle-Free Setup
    To ensure easy operation, this USB C to DisplayPort adapter supports plug-and-play installation, removing the need for additional software or drivers. CDP2DP14B is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note: • Your USB-C device must support DP Alt Mode to work with this adapter. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4. • This product will not work with the Samsung S8 smartphone. For hassle-free compatibility with the S8 we recommend using CDP2DP .
StarTech USB C to DisplayPort Adapter, 8K/5K/4K USB Type C to DP 1.4 Alt Mode Video Converter, HBR3/DSC/HDR, 8K 60Hz, Thunderbolt 3 Compatible DisplayPort 1.4 Monitor Display Adapter - 8K USB-C to DP Adapter (CDP2DP14B) - DisplayPort adapter - USB-C to DisplayPort
DisplayPort adapter
1080p support, 4K120Hz support, 8K60Hz (7680 x 4320) support, 5K60Hz support, plastic housing, Ultra HD (4K) support, DisplayPort Alternate Mode support, 5K support, HBR3 support, HDR support, 7.1 audio channel support, 32.4 Gbps data rate, Display Stream Compression (DSC)
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - female (output)
Thunderbolt 3 / DisplayPort 1.4
3-year warranty
P/N: TB4CDOCK
DisplayPort adapter
6 cm
2.35 cm
1.5 cm
34 g
Connector
Thunderbolt 3 / DisplayPort 1.4, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1 cm
Shipping Weight
44 g
3-year warranty
P/N: TB4CDOCK
FLW4 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
FLW4 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
FLW4 StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
FLW4 StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £11.86
FLW4 StarTech.com 3m 9.8ft DisplayPort 1.4 Cable In Stock £23.75
FLW4 StarTech.com 5m DisplayPort 1.4 Cable In Stock £30.35
FLW4 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
