Microsoft Surface Pro Ethernet Adapter
Quicklinx: 9K03WS00 Mfr#: 3U7-00002
Use the Surface Ethernet Adapter to connect your Surface Pro, Surface Pro 2, or Surface Pro 3 to your network when Wi-Fi is not available.
Microsoft Surface Ethernet adapter - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
6.2 cm x 2.2 cm x 1.7 cm
26 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1-year warranty
Surface Pro, Pro 2, Pro 3
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x 1000Base-T - RJ-45
1 x network cable (integrated) - 2.13 m
6.2 cm
2.2 cm
1.7 cm
26 g
Limited warranty - 1 year
Microsoft Surface Pro, Pro 2, Pro 3
