Designed for and working exclusively with Surface Pro, this proprietary Mini DisplayPort to VGA adapter lets you share photos, video, and presentations. Plug Surface Pro in to VGA-compatible displays, monitors, or projectors, and share your pictures, videos, and big ideas. Create, connect, and collaborate, at work or at home.
- Works exclusively with Surface Pro
- Lets you share pictures and video
- Connect to VGA-compatible displays
Product Specifications
- Type Display adapter
- Connector Mini DisplayPort - male
- Connector (Second End) HD-15 - female
- Manufacturer Warranty 1 year warranty
- Microsoft Surface Mini DisplayPort to VGA Adapter - video converter
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - Mini DisplayPort , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 23.3 cm x 3.35 cm x 1.48 cm
- Pricing Type
- Commercial
- 1-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- OS Required
- Windows 8.1 / 10
- Cables Included
- 1 x video cable
- DisplayPort 1.1a
- 23.3 cm
- 3.35 cm
- 1.48 cm
- 37.6 g
- Pricing Type
- Commercial
- Limited warranty - 1 year
