Listen to digital music straight from your CD or DVD with this aesthetic and yet powerful 2.1 speaker system. Comes with state of the art PCM technology to decode digital to analog signal directly from your favourite music tracks. Equally suitable for media player, and PC/ Notebook application.All cabinets made from quality wood material for warm sound and good sound characteristics. Beautiful finishes making it extremely presentable in your living or study rooms. Ideal for multimedia applications, connect easily to most media player, such as Mp3/Mp4, CD/DVD player, TV or PC. Listen to your favourite Mp3 songs with this system in uncoloured audio and deep vocals.
Enjoy clear music and high notes from quality satellites with 3" tweeter and 1" Dome drivers.
Powerful bass with 6.5" woofer driver for greater mass movements.
System utilizing bass reflex technology for deeper bass and depth in resolutions. Front panel with source selector, master volume, treble and bass level controls. Includes an infrared remote control for quick control.
Features:
Powerful amplified 2.1 speaker system with digital music functions
System with total power of 45 Watt RMS
Support digital PCM sound input
All wooden cabinets for natural sound production
Ideal for gaming, music and pc applications with easy 3.5 mm stereo input connection
Full audio spectrum performances, ideal for your favourite entertainment from Mp3, Mp4, CD/DVD movies and digital playbacks
Comes with digital optical TOSLINK and COAXIAL connectors
Clear highs with double 3", and double 1" tweeters
Deep bass with 6.5" woofer driver
Bass reflex tunnel for deep bass and vocals
Front panel controls for quick and easy access
Technical Specifications
Amplifier specs
Output power - 45, Watt RMS
Power distribution - 10x2 +25, Watt
Harmonic distortion - 0.3, % (1Watt, 1kHz)
Frequency response - 50-20 000, Hz
Signal/Noise ratio - 75, dB
Separation - 40, dB
Speakers specs
Tweeter driver type - 1+3 ,
Bass driver type - 6.5,
Material - MDF
Color - black
Remote control - 1
Output - 2RCA
Input - 3.5 mm stereo
Auxilliary - TOSLINK COAXIAL
Dimensions
Satellites - 96?215?108, mm
Subwoofer - 190?268?378, mm
Product Net weight - 6,1, kg
- Microlab M-910 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Nominal Output Power (Total)
- 45 Watt
- Frequency Response
- 50 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 10 Watt , 1 x subwoofer 25 Watt
- Power
- AC 120/230 V (50/60 Hz)
- 6.1 kg
- Product Type
- Enclosure Design
- Bass reflex
- Enclosure Material
- Wood
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 45 Watt
- 50 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Total Harmonic Distortion
- 0.3%
- Amplifier
- Integrated
- Controls
- Volume, treble, bass
- Speakers Included
- 2 x satellite speaker - 10 Watt , 1 x subwoofer - 25 Watt
- Driver Details
- Satellite speaker: tweeter driver - 3" , Satellite speaker: tweeter driver - 1"
- Driver Details (2nd speaker)
- Subwoofer: woofer driver - 6.5"
- Connector Type
- Audio input (mini-phone stereo 3.5 mm) , Digital audio input (coaxial) (RCA) , Digital audio input (optical) (TOS Link) , Audio output (RCA x 2)
- Included Accessories
- Audio cable, digital audio cable (optical), remote control, coaxial cable
- Power Source
- AC power adapter
- Voltage Required
- 6.1 kg
- Dimensions (WxDxH) / Weight Details
- Subwoofer: 19 cm x 37.8 cm x 26.8 cm , Satellite speaker: 9.6 cm x 10.8 cm x 21.5 cm
