Great sounds matters
This system features top quality satellites that perform near perfect linear frequency response curve. Powerful subwoofer with fantastic depth for accurate sound production from all your playback media. Attention to details, this system is truly a must for all who appreciate music and multimedia entertainment.
Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen. This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology.
Features:
- Powerful and crystal clear sound system
- 2.1 + 1 setup with standalone amplifier
- Low distortion noise and accurate reproduction
- Full range sound production with deeper bass using subwoofer
- All wooden speaker cabinets for excellent audio
- Connects to most media players such as Mp3/Mp4, LCD TV, computer and CD/DVD
- Front panel control and connections
Technical Specifications:
Amplifier:
Output power: 54 Watt RMS
Power distribution: 15 Watt x 2 + 24 Watt
Harmonic distortion: < 0.3% 1 W 1 kHz
Frequency response: 35 Hz -20 kHz
Signal/Noise ratio: > 75 dB
Separation: > 45 dB
Input sensitivity: 350 mV
Speakers:
Tweeter driver type: 2.5" x 2
Tweeter rated power: 15 Watt 4 ohm
Subwoofer driver type: 6.5"
Subwoofer rated power: 30 Watt 8 ohm
Interfaces:
Output: 3RCA sockets
Input: 3.5mm Stereo, 2RCA
Power:
Power supply: AC 220 V - 240 V, 50 Hz 200mA, or 100 V - 120 V, 460 mA versions
Package Contents:
FC360 amplifier
FC360 subwoofer
FC360 satellites x 2
2RCA - 3.5 mm stereo cable
User manual
Dimensions:
Subwoofer: 255 x 255 x 287 mm
Satellites: 89 x 202 x 102 mm
Amplifier: 75 x 200 x 200 mm
Product net weight: 9.4 kg
Giftbox dimension: 434 x 304 x 406 mm
Giftbox gross weight: 10.3 kg
Export carton: 623 x 446 x 425 mm
Export carton gross weight: 21.9 kg
