Microlab Bluetooth Speaker with 4W Rechargeable Battery - White
Quicklinx: 9T2BWS00 Mfr#: MD312W
Uniquely designed 2.1 speaker system in a single compact sound box. Aesthetic in design, it fits into most room types such as bedroom, kitchen or even your studies.
Connects wirelessly to your Bluetooth wirelessly technology enabled mobile phone or media player. Enjoy music without any messy cables from the music source. Listen to your favorite music from your mobile phone, tablet, or notebook. Alternatively you can connect to traditional 3.5 mm stereo music source.
Highly portable, this system features rechargeable battery and hand grip that lets you use it almost anywhere.
2.1 speaker system for full range music production
Wireless music with Bluetooth® technology
Generous bass effects and clear treble
Front panel controls for playback and Bluetooth® pairing functions
Comes with alternative 3.5mm stereo connection to most media players and computer
Rechargeable battery powered for portable use; carry it with you -True wireless, no cable needed for audio playback;
  • CSR latest lossless transmission Bluetooth chipset to ensure a lossless transmission;
  • Stylish design available in 3 iPod colors;
  • Built-in rechargeable battery make sure that you can take it anywhere you want
  • Built-in 2.1 powerful amplifier and US TI DSP technology to ensure an awesome audio performance
Microlab MD312 - speaker - for portable use - wireless
Speaker - for portable use - 2.1-channel
Speaker Type
Active
Continuous Power
4 Watt
Frequency Response
40 - 18000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo x 2 - 1.25 Watt - 4 Ohm - active , Speaker - subwoofer - 1.5 Watt - 2 Ohm - active
White
Power Options
USB charging
Speaker battery rechargeable - lithium
17.5 cm x 10.9 cm x 17.8 cm
1 kg
Enclosure Colour
White
Enclosure Material
Plastic
Speaker System
Speaker Type
Active
Continuous Power
4 Watt
Frequency Response
40 - 18000 Hz
Signal-To-Noise Ratio
65 dB
Total Harmonic Distortion
5%
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Controls
Power on/off, volume
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x tweeter driver - 2" , Speaker: bass driver - 3"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, USB charging adapter
Power Source
Options
USB charging
Rechargeable - lithium
17.5 cm
10.9 cm
17.8 cm
1 kg
