Honeywell's MS9520 Voyager hand-held, single-line laser scanner offers aggressive scanning of all standard 1D bar codes. The Voyager series of hand-held, single-line bar code scanners has united form with function in becoming the industry benchmark for value and performance.
This sleek scanner features patented automatic infrared activation and decodes all standard 1D bar codes. For presentation scanning, Honeywell offers a stand with automatic in-stand detection technology.
The MS9521 VoyagerHD is ideal for applications that require high density scanning, delivering quick and accurate scanning of 1D bar codes as small as 3 mil. Expand scanner functionality by purchasing the MS9524 VoyagerPDF, which delivers aggressive scanning of all standard 1D bar codes, including PDF.
Automatic trigger
Use the scanner either as a handheld device or a fixed presentation scanner when mounted in the stand. -
650-nanometer laser
High-visibility laser allows user to place laser line on selected bar code. -
Flash ROM
It protects investment with firmware updates via MetroSet2 software and a standard PC. -
Data editing
It allows to format bar code data to meet host system's specific requirements.
- Honeywell Voyager 9520 - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Light grey
- Minimum Bar Width
- 0.127 mm
- Scan Element Type
- Visible laser diode
- Scan Speed
- 72 line / sec
- Connectivity Technology
- Wired
- 7.8 cm x 5.6 cm x 19.8 cm
- 149 g
- 5-year warranty
- Light grey
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 0.127 mm
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Mode
- Single-pass
- Scan Speed
- 72 line / sec
- Skew (Degrees)
- 52
- Pitch (Degrees)
- 68
- Print Contrast Signal (PCS)
- 35%
- Decode Capability
- EAN/JAN, Code 93, Code 39, GS1 DataBar, Bookland, Code 39 Full ASCII, UPC-A, UPC-E, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, UPC-A/EAN-13 with Extended Coupon Code
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- Triggered, Reduced Space Symbology (RSS)
- 1 x USB
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable
- FCC Class B certified, UL, cUL, IEC 825-1/EN 60825-1 class 1, EN55022 Class B, ICES-003 Class B
- 7.8 cm
- 5.6 cm
- 19.8 cm
- 149 g
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 5 - 95%
- Drop Specification
- 1.5 m to concrete
