The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
- Maxtor M3 STSHX-M301TCBM - hard drive - 3 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 3 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Enclosure Colour
- Black
- 82 mm x 118.2 mm x 19.85 mm
- 236 g
- 3-year warranty
- Capacity
- 3 TB
- Interface
- USB 3.0
- 82 mm
- 118.2 mm
- 19.85 mm
- 236 g
Performance
- Interface Transfer Rate
- Software Included
- AutoBackup, Secure Drive, SecretZone
- OS Required
- Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8 / 10
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 5 °C
- 40 °C
