Maxtor 2TB M3 Portable USB3.0 External Hard Drive
Quicklinx: C1RMWS00 Mfr#: HX-M201TCB/GM
The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
What's in the box?
  • 1 x Maxtor M3 2Tb
  • USB 3.0 cable
  • Multi-language manual
Maxtor M3 STSHX-M201TCBM - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
SafetyKey
Power Source
USB bus
Enclosure Colour
82 mm x 112 mm x 17.5 mm
169 g
3-year warranty
2 TB
USB 3.0
SafetyKey
82 mm
112 mm
17.5 mm
169 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Software Included
AutoBackup, Secure Drive, SecretZone
Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8 / 10
1 x USB cable
Enclosure Colour
Shipping Width
13.7 cm
Shipping Depth
18.5 cm
Shipping Height
3.85 cm
Shipping Weight
309 g
Limited warranty - 3 years
5 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
