The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
What's in the box?
- 1 x Maxtor M3 1Tb
- USB 3.0 cable
- Multi-language manual
- Maxtor M3 STSHX-M101TCBM - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- SafetyKey
- Power Source
- USB bus
- Enclosure Colour
- Black
- 82 mm x 112 mm x 17.5 mm
- 151 g
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- SafetyKey
- 82 mm
- 112 mm
- 17.5 mm
- 151 g
Performance
- Interface Transfer Rate
- Power Source
- USB bus
- Software Included
- AutoBackup, Secure Drive, SecretZone
- OS Required
- Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8 / 10
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Shipping Width
- 13.7 cm
- Shipping Depth
- 18.5 cm
- Shipping Height
- 3.85 cm
- Shipping Weight
- 297 g
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 65 °C
