Matrox Dual Head2Go Digital SE
Quicklinx: 8BL2WS00 Mfr#: D2G-DP2D-IF
DualHead2Go DP Edition is an external multi-monitor upgrade for laptops and desktop computers. This small black box is the perfect tool for any business or professional user looking to increase their productivity with an energy-efficient two monitor setup. DualHead2Go DP Edition offers native support for DisplayPort equipment, providing a pure digital signal from system to monitors. It connects to the system's DisplayPort output and supports a wide range of resolutions - up to 3840x1200 (dual 1920x1200) across two monitors.
Matrox Graphics eXpansion Module DualHead2Go - Digital SE - video converter
Video converter
Max Resolution
3840 x 1200 (dual 1920 x 1200)
Max Monitors Supported
2
1 x DisplayPort input - 20 pin DisplayPort , 2 x DVI-D output - 24+1 pin digital DVI , 1 x USB (power only) - 4 pin USB Type B
9.65 cm x 6.35 cm x 2.79 cm
Video converter
Max Resolution
2
1 x DisplayPort input - 20 pin DisplayPort - female , 2 x DVI-D output - 24+1 pin digital DVI - female , 1 x USB (power only) - 4 pin USB Type B - female
USB powered, Matrox Clone, HDCP
Linux, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows XP / Vista / 7 / 8 / 10 (32/64 bits)
1 x USB cable - 91.4 cm , 1 x DisplayPort cable
Software Included
Matrox PowerDesk
9.65 cm
6.35 cm
2.79 cm
