StarTech.com 8in LFH 59 Male to Dual Female DisplayPort DMS 59 Cable
Quicklinx: B0MVWS00 Mfr#: DMSDPDP1
£16.33 ex VAT
£19.59 inc VAT
Connect two DisplayPort monitors to your DMS / LFH-equipped graphics card. TheDMSDPDP1DMS-59 to Dual DisplayPortCable allows you to split the video from a single LHF graphics card on to two DisplayPort (DP) monitors.
The DMS to DP Y cable supports high resolutions of up to 4k x 2k (3840 x 2160) with a maximum HBR2 bandwidth of 21.6 Gbps and iscompatible with DMS / LFH 59or DMS / LFH 60graphics cards such as Matrox, NVIDIA, PNY, ATI and HP.
The DMSDPDP1 is designed and constructed for maximum durability - making it a reliable and cost-effective replacement for damaged or misplaced DMS to 2x DisplayPortcables.
StarTech DMS-59 to DisplayPort - 8in - DMS 59 to 2x DP - Y Cable - DMS-59 Adapter - DisplayPort Splitter Cable - LFH Cable (DMSDPDP1) - display splitter - 20.3 cm
Display splitter
Molded, thumbscrews, strain relief
Cable Length
20.3 cm
Connector
2 x DisplayPort - female
Connector (Second End)
DMS-59 - male
RoHS
Display splitter
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Cable Length
20.3 cm
Connector
2 x 20 pin DisplayPort - female
DMS-59 - male
RoHS
