Overcome odd floor plans, annoying glare and awkward furniture placements that can diminish flat-panel TV experiences. Manhattan universal flat-panel TV tilting wall mounts with smooth, one-touch tilt adjustments help keep images, contrasts and colors clear, sharp and defined. VESA-compliant and constructed of quality materials, Manhattan universal flat-panel TV tilting wall mounts fit a variety of display sizes with a secure and confident above-the-floor installation. Ideal for residential, office, hospitality, classroom and conference room, digital signage and other commercial applications, Manhattan universal flat-panel TV tilting wall mounts bring high-performance LCD TV enjoyment front and center.
- Manhattan Universal Flat-Panel TV Articulating Wall Mount - wall mount
- Product Type
- Wall mount
- Adjustable Depth
- 8-25 cm
- Adjustments
- Tilt
- Recommended Use
- LCD / plasma panel
- Recommended Display Size
- 23"-42"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 20 kg
- Material
- Aluminium
- Limited lifetime warranty
- Adjustable Depth
- 8-25 cm
- Material
- Aluminium
AV Furniture
- Wall mount
- Mounting Components
- Tilt/swivel wall mount
- Recommended Use
- 23"-42"
- Adjustments
- Tilt
- Max Load Weight
- 20 kg
- Swivel adjustment
- Limited warranty - lifetime
