Easily put a projector in place and keep it in prime position. Manhattan Universal Projector Ceiling Mounts hold projectors stable and steady with precise tilt, 360° swivel and height adjustments that keep images clear, sharp and defined. Constructed of lightweight, quality aluminum materials, Manhattan Universal Projector Ceiling Mounts fit a range of models with a secure, confident and balanced overhead installation. The ceiling plate fits a range of ceiling slopes. Internal cable management helps conceal unsightly cords and connections for a professional, finished appearance. Ideal for home theater, auditorium, office, retail, classroom, video conferencing and other commercial applications, Manhattan Universal Projector Ceiling Mounts help focus attention where it matters most.
- Manhattan Universal Projector Ceiling Mount - ceiling mount
- Product Type
- Ceiling mount
- Adjustable Height
- 122-202 cm
- Adjustments
- Tilt
- 5.8 kg
- Recommended Use
- Projector
- Max Load Weight
- 15 kg
- Material
- Steel
- Silver
- Limited lifetime warranty
- Adjustable Height
- 122-202 cm
- 5.8 kg
- Material
- Steel
- Silver
AV Furniture
- Ceiling mount
- Mounting Components
- Ceiling mount
- Recommended Use
- Projector
- Cable Management
- Cable Management System (CMS)
- Adjustments
- Tilt
- Max Load Weight
- 15 kg
- Adjustable height, swivel adjustment
- Limited warranty - lifetime
