Maclocks Cling-On Wall Mount is a new iPad Lock and Stand designed to offer full functionality with a high security solution.
It is compatible with a variety of tablet models making it a near universal tablet security solution.
The Cling-On bracket is made of high grade steel. Securing your tablet are tamper-proof screws that tighten the bracket around the narrow side of the device, locking it to the base. The Cling-On bracket has 90 degree screen rotation that allows your tablet to be displayed in either landscape or portrait orientation mode, with the ability to fix the angle as desired. This feature makes it perfect for use as an iPad POS stand, retail kiosk, public display and desk companion.
- Compulocks Cling-On mounting kit - for tablet
- Product Type
- Mounting kit
- Mounting Components
- Wall mount
- Rotation
- 90°
- Recommended Use
- Tablet
- Recommended Display Size
- 12"
- Material
- High-grade steel
- Material
- High-grade steel
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Tablet
- 12"
- Rotation
- 90°
