Well it doesn't get much easier, you can mount the Mac mini using a security bracket to any surface utilizing the standard set of 75 or 100 VESA mount holes. This Mac mini mount is made from 100% solid high grade aluminum construction and makes for a great security solution. You slide the Mac mini into the Mac mini mount and security bracket, secure the lock in place and you are good to go - all in seconds. The loop-ended security cable is galvanized steel and the cable can be looped around a stationary object.
Versatile placement
Designed for flexibility, this Mac Mini Security Mount can be easily mounted under desks or on walls, providing a secure and out-of-the-way solution for your Mac Mini -
Durable construction
Crafted from high-quality aluminum, the Mac Mini Security Mount ensures a sturdy and reliable hold, protecting your device from theft or tampering -
Enhanced compatibility
With VESA interface support along with rear and top mounting options, this system security kit offers a seamless fit for your Mac, enhancing its usability and security without compromising on design
- Compulocks Mac Mini Security Mount - system security kit
- Product Type
- System security kit
- Placing / Mounting
- Wall mountable, under-desk mountable
- Package Content
- Lock
- Product Material
- Aluminium
- Top mountable, rear mountable, VESA interface support
- Designed For
- Apple Mac mini (Early 2020, Early 2023, Late 2012, Late 2014, Late 2018, Late 2020, Mid 2020)
- Product Type
- Product Material
- Aluminium
- Package Content
- Lock
- Designed For
Maclocks Universal Laptop Cable Lock | In Stock | £20.66 |
Maclocks Laptop combo cable lock | In Stock | £22.61 |
