Maclocks has developed the first locking and anti-theft solution for the new Mac Pro powerhouse computer. A must have for Mac Pro users on any scale - perfect for computer labs, educational institutions, graphic design and recording studios.
The new Mac Pro Lock Bracket with Security Cable Lock fits comfortably underneath the cylinder lid to offer complete protection of the device and its hardware components. By designing the Mac Pro Lock to fit the curvature of the new Mac Pro and the bracket plate to sit securely over the power cable the lid is now doubly locked into place. The bracket plate has an extended lip that will allow you to attach the included Security Cable Lock ensuring your Mac Pro workstation and all its impressive (and expensive) hardware are not going anywhere.
Before locking the Security Cable to the bracket you will first want to tether the loop end around a solid and stable object like the leg of a table or desk. If you don't have a secure place to tether the cable to, select an anchor point from the drop-down selection and you'll be covered.
The simple design of the Mac Pro Lock system means it is really quick and easy to setup and secure your Mac Pro in minutes.
Robust security
Crafted from high-grade stainless-steel, this security bracket and keyed cable lock system offers a solid layer of protection to your Mac Pro. Its durable construction ensures your device remains secure in any environment, providing peace of mind for users. -
Seamless compatibility
Designed specifically for Mac, this locking bracket and cable lock seamlessly integrate with your Apple Mac Pro's design. The precision fit ensures your device's aesthetics are not compromised, while offering a secure way to protect your investment.
- Compulocks Apple Mac Pro Locking Bracket and Keyed Cable Lock - Black - security bracket
- Product Type
- Security bracket
- Package Content
- Cable lock
- Black
- Product Material
- Stainless steel
- Product Type
- Security bracket
- Product Material
- Stainless steel
- Package Content
- Cable lock
- Black
