How does it lock? The first component of the iPad 2/3/4 lock is a hard plastic case you can leave on for everyday protection. And since the iPad has no security slot, the case has one built in. That way you can lock the security cable to the case, and loop the cable's other end around a fixed object (like a table). Once the case and cable are locked together, thieves can't detach the case without damaging the iPad. Likewise, the strong steel cable will discourage any thief. Weighing less than one pound, the cable is extremely sleek and its lock-head has the smallest diameter of any computer lock in the world. This makes the iPad lock flexible and light, not to mention stylish, so you can easily pack it in your bag and take it with you wherever you go! The last component is the iPad rotating security stand. The iPad security case locks in seconds onto the iPad rotating security stand as shown in the picture. This solution is effective and very clean looking.
- Compulocks - protective case for tablet
- Product Type
- Protective case for tablet
- Material
- Plastic
- White
- Material
- Plastic
- White
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Protection
- Scratch-resistant
- Included Accessories
- Security cable (2m), tablet desktop stand (white)
- Security lock slot (cable lock sold separately), camera lens cutout, anti-glare, speaker cutout, port cut-outs
