Equipped with a professional image sensor with low noise and vivid color reproduction, it supports extremely tremely high definition Full HD 1080p, SXGA, and vanes signal formats for crystal-clear image. Highly flexible and joint-free gooseneck design ensures smooth quality without vibration, easy to use, and 3600 viewing angle.
Excellent image quality
Equipped with a professional image sensor with low noise and vivid color reproduction. It supports extremely tremely high definition Full HD 1080p, SXGA, and vanes signal formats for crystal-clear image. -
Video/audio recording and extra storage
With a built-in microphone and just one-button to record video and audio synchronously on board directly without a PC. The SD card storage is convenient to record training, meetings, seminars, lectures. -
Built-in power
With a much more stable power supply and less things to detach you can be sure of a constant image and data flow. -
HDMI interface
Utilize a standard HDMI interface for the high quality digital video transmission, and simplify system integration. -
Anti-reflection
With the Lumens side lamp gooseneck design, the direction of the light source can be adjusted according to the environment to prevent reflections -
Auto tune
With the convenient single button to adjust the clarity, brightness, and color according to the actual environment automatically. -
Extremely smooth dynamic image
With 30 fps capture every tiny movement during playback without delays. Even flapping insect wings can be clearly observed in great detail. -
Joint-free gooseneck
- Lumens DC 170 - digital document camera
- Digital document camera
- Audio
- Yes: built-in microphone
- 42 cm x 14 cm x 39.5 cm
- 1.9 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 8.5 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Focus Adjustment
- Automatic (min distance 4 cm)
- USB 2.0, VGA, HDMI
- Digital image rotation, SD-card slot, image flip, image mirror, built-in LED lights, security lock slot (cable lock sold separately)
- Audio Support
- Wired
- 42 cm
- 14 cm
- 39.5 cm
- 1.9 kg
Camera
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 10
- Frame Rate (max)
- Still Image Capture Resolution
- 1280 x 960, 1024 x 768, 1280 x 768, 1920 x 1080
Lens Construction
- Optical Zoom
- 8.5 x
- Focus Adjustment
- Automatic
- Min Focus Distance
- 4 cm
- Video
- VGA, HDMI
- Computer Interface
- USB 2.0
- 1 x USB 2.0 - 4 pin USB Type B , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI output - RCA , 1 - RS-232/composite video output , 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio - output
- Power Device
- Power supply - internal AC 120/230 V
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7
