Logitech Unifying Receiver - Wireless Mouse/Keyboard Receiver USB
Quicklinx: D8B4WS00 Mfr#: 910-005236
The Logitech Unifying Receiver is a tiny wireless receiver that can stay plugged into your notebook's USB port and lets you easily connect up to six compatible wireless mice and keyboards to the same receiver. There's no need to unplug it when you move around, so you won't have to worry about losing it.
With a Logitech Unifying Receiver you get wireless freedom and convenience without the hassle of multiple receivers. It's easy to add a compatible wireless mouse or keyboard to the same receiver. And your wireless devices are ready when you need them.
  • TINY, LEAVE-IN RECEIVER
    Our smallest Unifying receiver. So tiny that you can leave it in your notebook, so there's no need to unplug it when you move around
  • LOST YOUR UNIFYING RECEIVER?
    Use this stand-alone USB Unifying receiver to replace a lost one. It's compatible with all Logitech Unifying products (look for Unifying logo displayed on compatible products)
  • ADDITIONAL RECEIVER FOR LOGITECH DUAL CONNECTIVITY DEVICES
    Use an extra Unifying receiver to connect a dual connectivity mouse or keyboard - or both - to a second computer. Then switch from one computer to the other with the push of a button for efficient multi-tasking. It can also be a great add on for your Logitech Flow setup
  • LOGITECH ADVANCED 2.4 GHZ WIRELESS TECHNOLOGY
    Advanced 2.4 GHz wireless technology provides a powerful, reliable connection up to 10 meters away with virtually no delays or dropouts
Logitech Unifying Receiver - wireless mouse / keyboard receiver - USB
Wireless mouse / keyboard receiver
Interface Type
USB
0.9 cm x 0.6 cm x 1.5 cm
1.23 g
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.10 or later
Interface Type
USB
0.9 cm
0.6 cm
1.5 cm
1.23 g
1 x USB - 4 pin USB Type A
Limited warranty - lifetime
