Logitech Unifying Receiver - Wireless Mouse/Keyboard - USB
Quicklinx: J4B8WS00 Mfr#: 910-005931
21 In Stock
£8.42 ex VAT
£10.10 inc VAT
The Logitech Unifying Receiver is a tiny wireless receiver that can stay plugged into your notebook's USB port and lets you easily connect up to six compatible wireless mice and keyboards to the same receiver. There's no need to unplug it when you move around, so you won't have to worry about losing it.
With a Logitech Unifying Receiver you get wireless freedom and convenience without the hassle of multiple receivers. It's easy to add a compatible wireless mouse or keyboard to the same receiver. And your wireless devices are ready when you need them.
  • Simplify, diversify, unify
  • One tiny receiver, many possibilities
  • Mix, match, unify
    They've got a range of products that you can connect to a single, tiny receiver you can leave plugged into your notebook. Create the combo that works for you.
  • Works great for work
    Notebook computers aren't just for road warriors anymore. See what makes the Unifying Receiver and compatible mice and keyboards the ideal wireless solution for your business.
Logitech Unifying Receiver - wireless mouse / keyboard receiver - USB
Wireless mouse / keyboard receiver
Interface Type
USB
0.9 cm x 0.6 cm x 1.5 cm
1.23 g
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.10 or later
Interface Type
USB
0.9 cm
0.6 cm
1.5 cm
1.23 g
1 x USB - 4 pin USB Type A
Brand: Logitech
