Logitech Ultrathin Magnetic Keyboard Cover for iPad Air 2
Quicklinx: B4M3WS00 Mfr#: 920-006530
A fast and accurate typing experience is ensured because of Ultrathin's optimized keyboard layout, well-spaced keys and iOS shortcuts. Easily connect with Bluetooth. Find the ideal angle for typing with the flexible multi-angle slot for your tablet. Slide tablet towards the magnetic clip and it pops up right when you need it. When you're on the go, strong magnets keep your tablet secured to Ultrathin.
  • Great typing
    A fast and accurate typing experience because of Ultrathin's optimized keyboard layout, well-spaced keys and iOS shortcuts. Easily connect with Bluetooth
  • Adjusts to you
    Find the ideal angle for typing with the flexible multi-angle slot for your iPad
  • Magnetically clips onto iPad
    Slide iPad towards the magnetic clip and it pops up right when you need it.When you're on the go, strong magnets keep your iPad secured to Ultrathin
  • Thin, light and perfectly matches iPad
    At 6.4mm thin and a matching aluminum finish, Ultrathin is the other half of iPad
  • Auto wake, auto sleep
    Ultrathin wakes iPad when you open the cover and puts it to sleep when you close it
  • Two year battery life
    Ultrathin's lithium battery lasts for 2 years and is easy to replace when needed
Logitech Ultrathin - keyboard - UK - space grey Input Device
Keyboard
Bluetooth
Wireless
Localization and Layout
Integrated tablet stand, sleep mode, magnet closure, adjustable tablet viewing angle
Space grey
24 cm x 17.36 cm x 0.64 cm
322 g
Keyboard
Bluetooth
Max Operating Distance
Up to 10 m
Wireless
Keyboard Technology
Scissors
24 cm
17.36 cm
0.64 cm
322 g
Space grey
Micro-USB power cable
