Logitech Combo Touch Keyboard and Folio Case for Apple 11-inch iPad Pro (1st,2nd,3rd gen)
Quicklinx: GS65WS00 Mfr#: 920-010148
£157.65 ex VAT
£189.18 inc VAT
The Logitech Combo Touch keyboard case provides form-fit protection for iPad. The Multi-Touch trackpad enables precise navigation and a detachable keyboard offers flexibility for different tasks. Users can easily type, sketch, view and read, whether they're at their desk or on the go. Combo Touch brings versatility to iPad, enhancing the user experience and promoting productivity anywhere.
  • TAKE iPAD FURTHER
    Power your passion from anywhere. Meet the keyboard case that enables whole new levels of versatility and protection. Multiple use modes allow you to easily type, view, sketch, read and more with Combo Touch for iPad Pro. Possibilities? Endless
  • THINNER. LIGHTER
    The new Combo Touch is the thinnest and lightest yet; it slips into bags, travels light, and powers your productivity anywhere
  • LARGEST TRACKPAD EVER
    The biggest trackpad ever made for Combo Touch. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more
  • PREMIUM MATERIALS
    Thoughtfully designed with sustainable, premium materials that feel as good as they look. Experience elegance with our sleek, low-carbon aluminum bottom and newly formulated, luxuriously soft-touch textiles
  • USE-YOUR-WAY MODES
    Multiple use modes and infinite possibilities. Switch it up to type, sketch, watch videos, read, or hop on a video call
  • DETACHABLE, FULL-SIZED KEYBOARD
    Large, well-spaced keys give your hands plenty of room to type comfortably, while scissor keys give you that perfect bounce. Done typing? Just detach the keyboard to sketch, watch or read with total freedom
  • MULTI-TOUCH TRACKPAD
    The precise, click-anywhere trackpad provides that superior, intuitive tracking experience you need to make things happen. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more
  • FLEXIBLE KICKSTAND
    Find your preferred angle for just about any task with the ultra-flexible kickstand
  • SECURE, FORM-FIT PROTECTION
    The sturdy and portable case keeps your iPad Pro safe from scuffs and scratches, so you can take it anywhere with total peace of mind
  • TYPE AWAY, DAY OR NIGHT
    Adjustable backlit keys enable your mood-lit work sessions to be even more enjoyable than ever
  • POWER, PAIR, AND CHARGE
    Smart Connector technology enables seamless, instant, secure connectivity with no need to charge-it's powered by iPad
  • SUPPORTS APPLE PENCIL
    Combo Touch is designed to let you attach Apple Pencil right to iPad. No need to remove the case
Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey Input Device
Keyboard and folio case
Backlit
16-level
Apple Smart connector
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, backlight control, volume -, volume +
Protection
Bump protection
Oxford grey
Case Material
Woven fabric
25.2 cm x 18.93 cm x 1.69 cm
574 g
Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation)
Backlit
16-level
Hot Keys Function
QWERTY UK
Built-in Devices
Trackpad
Protection
Bump protection
25.2 cm
18.93 cm
1.69 cm
574 g
Carrying Case
Material
Woven fabric
Ports and controls access, protective corners, auto sleep/wake function, Apple pencil holder, 20°-60° adjustable angles, backlit auto-adjusting
Oxford grey
Apple iOS 13.4 or later
Brand: Logitech
