Logitech Rally Mic Pod - Microphone
Quicklinx: FFJWWS00 Mfr#: 989-000430
More than 50 In Stock
£270.48 ex VAT
£324.57 inc VAT
Good looks meet great sound RightSound technologies automatically focus on the active speaker Connect up to 7 Rally Mic Pods to cover larger rooms Premium materials and design pair beauty with performance Automatic equalization of loud and soft voices
  • Hear Every Voice Clearly
    With RightSound technology and multiple beamforming elements in every individual mic pod, the audio focus is always automatically on the active speaker. A single mic pod provides coverage for up to ten people. Larger meeting spaces can be provisioned with up to seven mic pods working in concert to receive and transmit remarkably clear audio for every individual at the table
  • Simplified Cabling
    Up to 7 Rally Mic Pods can be daisy-chained together with a single cable connection to the Rally table hub. For U-shaped tables or single-wire cabling through grommets, the Rally Mic Pod Hub accessory provides three connections for optimal positioning and to bring mute control within easy reach
  • Premium, Low-Profile Design
    Rally Mic Pods are elegant and deceptively small for their remarkable range and sensitivity. As RightSound suppresses ambient background noise by applying acoustic echo and noise reduction, non-slip pads beneath the mic pods help to isolate the microphones from table vibrations (like keyboard taps). Advanced materials resist fingerprints and stains. Plus, a red LED on top of each mic pod provides visual confirmation when muted
  • An Equal Voice
    RightSound voice equalization and beamforming technologies mean you don't need to raise your voice to be heard. Rally Mic Pod listens for every voice, not just the loudest ones, so you can hear and understand those with softer voices or who are seated further away. Behind the scenes, the Rally table hub can switch between acoustic beams up to 125 times/second to smoothly capture the most lively conversations
  • Enhanced Sensitivity
    Rally is designed from the ground-up for maximum sensitivity with minimal interference. By putting speakers by the screen and microphones near the participants, Rally offers an intuitive audio experience with naturally reduced echo and interference. But that's not all: Rally Speaker features a patent-pending suspension system to prevent interference from vibration and resonance. This means that Rally Mic Pod can offer enhanced sensitivity that tabletop speakerphone designs can't match
Logitech Rally Mic Pod - microphone
Microphone
Recommended Use
Conference
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Rally, Rally Plus, Rally Bar, Rally Bar Mini
Microphone
Recommended Use
Conference
Microphone
Omni-directional
Wired
Sensitivity
-27 dB
Frequency Response
90 - 16000 Hz
Noise Cancelling
Mute function
Audio Input Details
Omni-directional - 90 - 16000 Hz
Logitech Rally, Rally Plus, Rally Bar, Rally Bar Mini
FFJW Logitech Rally Mic Pod Mount In Stock £61.22
Brand: Logitech
