Logitech Mic Pod Table and Ceiling Mount - White
Quicklinx: GH4JWS00 Mfr#: 952-000020
£63.51 ex VAT
£76.21 inc VAT
Elevate the appearance of meeting rooms equipped with Rally and Rally Plus. With a compact footprint and clever design details, Mic Pod Mount anchors Rally Mic Pods in place, provides a hidden path for cabling, and coils excess cable beneath the table.
  • MIC POD MOUNT
    Elevate the appearance of meeting rooms equipped with Rally Mic Pods. With a compact form factor and clever design, Mic Pod Mount anchors mic pods in place, provides a hidden path for cabling, and neatly coils excess cable
  • PERFECTLY PLACED
    Say goodbye to visible cables and wandering mic pods. Mic Pod Mount gives meeting rooms a finished look while making sure that mic pods stay connected, meeting after meeting. Shown with Rally Mic Pod (not included)
  • FITS MOST TABLES
    Mic Pod Mount anchors mics and routes cables through grommet holes from 25 - 65 mm in diameter, and adjusts to tables up to 50 mm thick
  • MOUNTS TO CEILINGS
    Equally at home on the ceiling, Mic Pod Mount offers ultimate flexibility for multipurpose rooms, classrooms, and other reconfigurable spaces
Logitech Rally Table and Ceiling Mount for Rally Mic Pod bracket - for microphone - white
Bracket - ceiling mountable
14.6 cm x 14.6 cm x 9 cm
Recommended Use
Microphone
White
Package Content
Screws, mounting plate, mount cup, threaded rod, nut, cable spool
Rally Bar, Bar Mini, Mic Pod, Plus; Room Solution Large
14.6 cm
14.6 cm
9 cm
White
Package Content
AV Furniture
Bracket
Recommended Use
Microphone
Placing / Mounting
Ceiling mountable
Logitech Rally Bar, Bar Mini, Mic Pod, Plus , Logitech Room Solution Large
Brand: Logitech
