A portable speaker dock and alarm clock that delivers clear, balanced sound from your iPod® or iPhone™--in every corner of your room
The Logitech Pure-Fi Express Plus speaker dock for the iPod and iPhone features omnidirectional acoustic technology, which provides great sound at a consistent level, throughout the room. It also includes the ability to run on AC or battery power, making it easy to take your music from room to room, an alarm clock, so you can rest assured that you'll wake on time; and a wireless remote control that works from up to 10 meters (30 feet) away and stores neatly in an integrated compartment. In all, it's a great way to dock, play and charge your iPod/iPhone.
Speaker dock for iPod®/iPhone
You can dock, play, and charge your iPod® or iPhoneTM--without putting the iPhoneTM in airplane mode.
Clock with alarm
No need for a separate alarm clock--you can set your Pure-Fi Express Plus to wake you up.
Wireless remote control
It gives you control from up to 10 m away, and stores neatly in an integrated compartment.
Portable design
The integrated handle and AC or battery power make it easy to take your music from room to room.
360-degree sound
The speakers project sound evenly in all directions, so you enjoy rich, clear sound from any angle throughout the room.
One giant step for sound
Music isn't about staying still. It's about movement. Yet most speakers are designed to sound their best when you're sitting right in front of them.
But you don't have to just sit there and take it. You can choose speakers that sound good throughout the room--Logitech speakers with 360-degree sound.
Stuck in the middle with traditional speakers
With most speakers, you need to sit in the sweet spot - usually smack dab in the middle, depending on how you've arranged your system - to get the best sound. Dance around the room or pick a different seat and your audio just won't sound right.
That's because the high and mid frequencies drop out when you move to the side or back of the speaker. (Their shorter wavelengths don't wrap around the speaker like low frequencies.)
Moving all around with 360-degree sound
Our 360-degree speakers are different. They've got both forward- and backward-firing drivers that project sound more uniformly around the speaker over a wider range of frequencies--not just the low ones. That means the direct and reflected sound are more tonally balanced for a better, more immersive listening experience.
The result? A broad sweet spot that gives you rich, balanced sound in every corner of the room and everywhere in between. So, you can go ahead and make your move.
- Logitech Pure-Fi Express Plus - speaker dock - for portable use
- Product Type
- Speaker dock - for portable use
- Clock
- Speaker Type
- Active
- Amplifier
- Integrated
- Speaker System Details
- 1 x portable speaker
- Battery
- 6 x battery - AA type Alkaline
- 2-year warranty
- Designed For
- Apple iPod (4G, 5G); iPod classic; iPod mini
- Product Type
- Clock
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Controls
- Volume
- Additional Features
- Omnidirectional design
- Speakers Included
- 1 x portable speaker - wired
- Driver Details
- Portable speaker: 4
- Connector Type
- IPod docking , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, remote control, iPod adapter kit
- Remote Control
- Remote control - infrared
- Power Source
- Battery
- AA type Alkaline
- Required Qty
- 6
- Included Qty
- 0
- Limited warranty - 2 years
- Designed For
- Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
