POP Home Switch lets everyone in the home control smart lighting, music, and more with the push of a button. Program each switch with up to three custom commands to add creativity and convenience throughout your smart home.
POP THE LIGHTS
Whether it's movies, reading, or a party, POP makes it easy to match lighting with lifestyle. Use the POP app to configure your Philips Hue , Insteon , LIFX, or Lutron lights for brightness, warmth, and colour-then enjoy simple push-button control -
POP THE MUSIC
Program POP to play your Sonos favorites at just the right volume. Add lighting to the mix to create Recipes that instantly set the mood, from early morning waking up, to late night rocking out -
POP EVERYTHING, TOGETHER
Want to set the mood with lights AND music? Create Recipe combinations to trigger multiple smart devices at once, like setting smart locks and night-lights before going to bed. Or, when combined with a Harmony hub-based remote, use POP to start an Activity like "Movie Night "– the TV, cable and stereo turn on and smart lights dim -
POP NEARLY ANYWHERE
Because each switch is wireless and battery-powered, you can use POP just about anywhere. Mount one by the front door, keep one on your nightstand, or carry one from room to room. Use POP Add-On switches to add simple smart home control wherever you like
- Logitech POP Add-on - switch - Bluetooth, Wi-Fi - alloy
- Product Type
- Switch
- Power Source
- Battery
- Connectivity
- Wireless - Bluetooth, Wi-Fi
- Supported Host Device OS
- iOS, Android
- Alloy
- 1-year warranty
- 6 cm x 0.9 cm x 6 cm
- Product Type
- Switch
- Power Source
- Battery
- Connectivity Technology
- Android 4.4 (KitKat) or later, iOS 9 or later
- Alloy
- Warranty
- 1-year warranty
- 6 cm
- 0.9 cm
- 6 cm
- 37 g
