Logitech M560 Wireless Mouse - Black
Quicklinx: B8HCWS00 Mfr#: 910-003882
In free-spinning mode, you can coast smoothly through the longest documents. In click-to-click mode, you can step precisely through spreadsheets, photo albums or playlists. The tiny receiver practically disappears in your computer's USB port, so there's less chance of it being broken or damaged. Plus, you can easily add a compatible keyboard, number pad or even another mouse - without the hassle of multiple USB receivers.
  • Full-size, comfort-first design
    Deep, contours. Soft, rubber grips. Whether you're a righty or a lefty, your hand is cradled naturally and comfortably-hour after hour
  • Windows 8 edge menu button
    No matter what you're doing, you're always just one click away from the things you use most, like running apps, search and settings. A button located right behind the scroll wheel gives you one-touch access to the App Bar and Charms Bar
  • Two extra thumb buttons
    Switch instantly between the traditional Windows desktop and apps and the new, full-screen Windows 8 interface. Or customize the thumb buttons to do exactly what you want them to
  • Logitech Unifying receiver
    The tiny receiver practically disappears in your computer's USB port, so there's less chance of it being broken or damaged. Plus, you can easily add a compatible keyboard, number pad or even another mouse-without the hassle of multiple USB receivers
  • Advanced 2.4 GHz wireless connectivity
    You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Absolute comfort, hour after hour
    Whether you're a righty or a lefty, whether you use a fingertip or palm grip, your hand is cradled naturally and comfortably
  • Extra control right where you need it
    You get one-touch access to the Windows 8 App Bar, Charms Bar, Desktop and Start Screen
  • Hyper-fast scroll wheel
Logitech M560 - mouse - USB - black
Mouse
Wireless - USB
Orientation
Right and left-handed
Wireless Receiver
USB wireless receiver
Programmable side button, turbo scroll, Logitech Unifying receiver
Microsoft Windows 7, Windows 8
3-year warranty
Mouse
Wireless Receiver
Orientation
Input Device
Wireless
USB
1 x USB - 4 pin USB Type A
1 AA alkaline battery
Limited warranty - 3 years
