See More of What's Happening Outside, From The inside
See more of what’s happening outside, from the inside. Attach the Window Mount to Circle 2 and place it on any window pane to see outdoors. Watch over the front porch and driveway or overlook the backyard, from indoors. With the Circle mobile app in Window Mode, experience night vision, which eliminates glares and reflections. Thanks to the micro-suction ring and unique in-app mode, it’s honestly just that easy.
- Logitech camera mounting kit
- Product Type
- Camera mounting kit
- Package Content
- Camera cable (3m), cover, window ring, USB power adapter, 2 screws, 2 anchors, 2 USB cable clips, 2 window adhesive strips
- Placing / Mounting
- Window mountable
- Indoor / Outdoor
- Outdoor
- 7.4 cm x 7.4 cm x 5.3 cm
- 39 g
- 1-year warranty
- Product Type
- Package Content
- Window mountable
- Indoor / Outdoor
- Outdoor
- 7.4 cm
- 7.4 cm
- 5.3 cm
- 39 g
- Limited warranty - 1 year
