Versatile Accessory For Your Wire-Free Camera
Circle 2 Accessory Rechargeable Battery works with Circle 2 indoor/outdoor wire-free security camera only. Use it as a backup to power your Circle 2 camera while the other battery is charging. Circle 2 is the most versatile security camera that can be used anywhere at home. To customise your experience even more, choose from a selection of accessories that fit your needs.
Use this rechargeable battery as a backup battery for the Circle 2 wire-free camera. It can last up to 3 months on a single charge.
- Logitech battery - Li-Ion
- Product Type
- Battery
- Designed For
- Camera
- 8.2 cm x 8.2 cm x 4.2 cm
- 256 g
- Battery
- Lithium Ion - 6400 mAh
- 1-year warranty
- Product Type
- Battery
- Designed For
- Camera
- 8.2 cm
- 8.2 cm
- 4.2 cm
- 256 g
- Technology
- Lithium Ion
- Capacity
- 6400 mAh
- Limited warranty - 1 year
