Linksys X3000 ADSL Wireless Router
Quicklinx: 7QGKWS00 Mfr#: X3000-UK
  • IEEE 802.11n
Linksys X3000 Advanced Wireless-N ADSL2+ Modem Router
Create a high speed wireless home network suitable for your DSL or cable broadband connection.
Ideal for
- Sharing Internet access, surfing the web, emailing and printing wirelessly
- Connecting multiple devices and to add USB storage to the network
- Connecting to a DSL connection or cable modem
Key features
- All-in-one device - functions as a wireless ADSL2+ modem router or a wireless router
- Wireless-N router with wireless transfer speeds up to 300 Mbps
- Reliable range with MIMO antenna technology
- Four Gigabit Ethernet ports for speeds 10x faster than Ethernet
Built-in DSL modem
Directly connects you to the internet wirelessly --no separate DSL modem required. The Linksys X3000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
Fast wireless speed
The Linksys X3000 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates up to 300 Mbps.
Reliable wireless coverage
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Benefits of Gigabit
Use the four Gigabit Ethernet ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices like computers, hard drives, and servers.
Built-in StorageLink port and UPnP media server
The StorageLink USB port lets you add storage devices to your network to share files wirelessly throughout your home. The built-in UPnP AV media server enables media streaming to your Xbox 360, PS3, or other UPnP compatible devices.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network. Cisco Connect enables you to:
- Create a separate, password protected network for guests
- Limit access time and access to certain websites with parental controls
- Access advanced network settings easily
- Measure your connection speed with the Broadband Speed Meter
- Perform regular automated update checks for firmware and software with the option to install
  • Built-in DSL modem
    Directly connects you to the Internet wirelessly - no separate DSL modem required. The Linksys X3000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
  • Fast wireless speed
  • Reliable wireless coverage
  • Benefits of Gigabit
  • Built-in StorageLink port and UPnP media server
  • Advanced security
Linksys X3000 - wireless router - DSL modem - 802.11b/g/n - desktop, wall-mountable
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
DHCP support, MAC address filtering, parental control, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, RADIUS support, Wi-Fi Protected Setup (WPS), Stateful Packet Inspection Firewall (SPIF)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
20.2 cm x 16 cm x 3.4 cm
335 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Wireless router - 4-port switch (integrated)
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 40-bit WEP, 104-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UL, CB, FCC
Status Indicators
Power, WAN, LAN, wireless
Line Properties
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5 Annex A
WAN: 1 x ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
1 x phone cable
Software Included
Drivers & Utilities
20.2 cm
16 cm
3.4 cm
335 g
10 - 85% (non-condensing)
7QGK C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
7QGK C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
