High-gain wireless antennas offer an easy way to expand your wireless network's coverage. These antennas are equipped with omni-directional broadcast technology, which amplifies the signal strength of your Wi-Fi devices to deliver more wireless range and performance across the horizontal plane. This makes them ideal for large, single-story households that need a strong Wi-Fi signal.
Featuring Dual-Band support, these high-gain antennas can increase the signal to multiple devices connected to your network. Each of the high-gain antennas delivers up to 4 dBi on the 2.4 GHz band and up to 7 dBi on the 5 GHz band, offering up to 2x the antenna gain over stock antennas.
Compatible with any wireless device that uses a RP-SMA connection, these premium antennas are easy to use and install. Simply detach your router or Wi-Fi device's stock antennas and screw antennas into place - you'll immediately enjoy wider coverage throughout your home or office.
Dual-band performance for improved connections
Featuring dual-band support, these high-gain antennas can increase the signal to multiple devices connected to your network. Each of the high-gain antennas delivers up to 4 dBi on the 2.4 GHz band and up to 7 dBi on the 5 GHz band, offering up to 2x the antenna gain over stock antennas. -
Easy to attach
- Linksys WRT002ANT - antenna
- Product Type
- Antenna
- Packaged Quantity
- 2 (specifications are for single item)
- 2.6 cm 1 cm
- Length
- 28.8 cm
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Surface mountable, indoor
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- 7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
- Directivity
- Omni-directional
- Packaged Quantity
- Product Type
- Antenna
- 2.6 cm
- 1 cm
- Length
- 28.8 cm
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- Directivity
- Omni-directional
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 30°
Cabling & Wiring
- Connector Provided
- 1 x RP-SMA
