LightwaveRF Hand Held Group Controller for up to 12 Lighting & Power Mood Scenes
Quicklinx: 8HD7WS00 Mfr#: JSJSLW104WH
See How LightwaveRF Can Transform Your Home Into a Smart Home!
The LightwaveRF Connect Mood Remote Control has the ability to switch on/off or dim up/down any number of LightwaveRF devices simultaneously including dimmers and sockets. It also offers a quick and easy way to store and recall mood lighting settings. An All Off' feature is also included which will turn off all paired devices at the touch of a button. LightwaveRF will transform the way you control your home.<br /> </p><ul><li>Switch (on/off) or dim (up/down) any number of LightwaveRF Lighting, Power and Heating devices</li><li>Turn your LightwaveRF Light Switches and Power Sockets 'All Off' at the touch of a button </li><li>Intelligent Lighting Control, Store and Recall mood' lighting settings, Save Energy
  • Intuitive, easy setup and use
  • Spec
    • Wireless Type - LightwaveRF: 433.92MHz
    • Power - Battery: 3V CR2023 Lithium (included)
    • Fitting - Battery operated non-wired device
    • Operation - On-Off, Dim Up-Down
    LightwaveRF Connect Series - mood lighting switch - white
    Mood lighting switch
    Power Source
    Wireless
    Frequency Band
    433.92 MHz
    White
    3.5 cm x 1.5 cm x 12.5 cm
    Power Source
    Wireless
    Frequency Band
    433.92 MHz
    LED indicator
    CR2032
    Voltage Provided
    3 V
    White
    3.5 cm
    1.5 cm
    12.5 cm
    45 g
