LightwaveRF Gen 2 Power Starter Kit
Quicklinx: DL9BWS00 Mfr#: L422
Colours:
L422 - Power Starter Kit
Bring your home to life. Beautifully designed smart sockets to help control your appliances from wherever you are.
Begin your home automation adventure with the Power Starter Kit. With a Link Plus and a 2 gang smart socket, you'll have everything you need to start controlling your lamps, appliances, and more. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! This socket is quick and easy to DIY install.
HomeKit Control
Lightwave’s remote socket seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart devices from your smartphone or tablet, from wherever you are.
Wireless socket
A contemporary stainless steel or white metal finish and fully 3000W rated like any other 1 gang or 2 gang socket; however, you can control a Lightwave smart socket from your smartphone.
Feature rich
Our second generation smart socket enables real-time status updates of any connected appliances and built-in energy monitoring. All Lightwave sockets are also lockable to ensure family safety.
Simple installation
Standard wiring configurations make our smart wifi socket easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Control Lightwave devices
Link Plus compatible with Gen 1 & Gen 2 devices (excluding Gen 1 remotes and wire-free switches)
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
LightwaveRF L422 - 2nd Generation - Power Starter Kit - home automation kit - white, stainless steel
Home automation kit
Functions
Energy use monitor
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Package Content
Central controller, smart socket
Wireless
White, stainless steel
Home automation kit
Functions
Energy use monitor
Package Content
Wireless
Platform
Apple HomeKit
Compatible Services
IFTTT
Nominal Voltage
AC 230V
Warranty
Dimensions & Weight Details
Central controller: 10.1 cm x 3 cm x 10.1 cm x 218 g , Smart socket: 75 cm x 3 cm x 8.8 cm x 132 g
