Get started with a Starter Kit that includes an AC plug pack and 2m LED Strip. Extendable up to 10 meters Take complete control of your lighting. The free LIFX app is available on Android and iOS. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds. Get the most out of your LIFX by connecting with the rest of your smart home. LiFX works other Smart Products including Amazon Echo, Nest Thermostat and Protect, Logitech Pop and many more. Intuitive Control - Control lights individually, select beautiful themes and scenes, create custom groupings to easily control multiple bulbs at the same time
- 16 million colours and warm to cool whites
- Works with Alexa for voice control
- Easy to set up, built in Wi-Fi - NO HUB REQUIRED
The Lightbulb Reinvented
LIFX Z is the lighting strip that uses Wi-Fi to create the perfect light for you at any moment. A simple-to-use app allows you to fine tune your lighting experience; control your entire strip, or select colours for addressable zones - the choice is yours.
A Connected Home Should Be Easy
The LIFX Z is engineered to provide a simple way to start designing your connected home. A starter kit contains all the technology and hardware needed to use your lights. LIFX is ready to seamlessly integrate with some of your favourite smart home products, including Amazon Echo, Nest and SmartThings.
Highlights
- 2 metres of zoned lighting
- Easy set-up, no extra hardware
- Incredible colour, millions of possibilities
- Warm and cool white range
- Lasts up to 22.8 years*
- One app for Android, iOS & Windows 10
One App, Your Device
Take complete control of your lighting. The free LIFX app is available on Android, iOS and Windows 10. With a few taps on your tablet, phone or watch, colours go from bright and vibrant to pure whites in seconds.
Extendable
Click and connect up to 10 meters of individually controlled strip lighting segments. The LIFX Z has been specially designed to ensure that, when extended, your 1400 lumens increase by 700 lm per meter (rather than dimming like other strips) to a maximum of 2800.
In Tune with Your Needs
LIFX works to make connected living simple by responding to you. Arrive home and have your lights come on automatically or take control from your couch, bed or even work, the LIFX app lets you immerse your home in light, your way.
Prep & Peel
Wipe the surface clean to prepare it. Peel the backing sheet off the strip.
Stick
Adhere the strip to the surface by pressing and smoothing along.
Download
Download the free LIFX app available for iOS, Android and Windows 10.
Extend
Plug the pieces together - simple. We’ve got diagrams in the manual to help if you’re unsure.
Colour Zoning
The LIFX Z is the first LED light strip to have individually programmable colour zones. From subtle gradients, to bold contrasting colours, hand over control to your inner creative and relish in this new way to control LIFX.
The Connected Home Made Simple
LIFX lights combine built in features and intuitive integrations to make building your smart home easy. Connect your lights seamlessly with the likes of Amazon Echo, IFTTT, SmartThings and Nest.
Everything you need
With all the intelligence built into the light, it is easy to kick start your connected home. No technical skills or additional hardware needed. -
Seriously simple
No need for a hub or messy hardware. Just plug in, download and play! You can expand with LIFX at any time and unlock more features.
- LIFX Z Starter Kit - light strip kit - LED - 17 W - 16 million colours - 2500-9000 K - pearl white
- Product Type
- Light strip kit
- Light Source Type
- LED
- Dimmer
- Pearl white
- Wattage
- 17 W
- Wattage Equivalent
- 90 W
- Colour of Illumination
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 1400 lumens
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Google Home, Nest
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 Hz
- Product Type
- Light strip kit
- Dimmer
- Self-adhesive, indoor usage, Android compatible, iOS compatible, Wi-Fi controlled, Windows compatible, interchangeable plug types A, C, G, I
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 17 W
- 90 W
- 2500-9000 K
- Luminous Power
- 1400 lumens
- Lifetime
- 22.8 years
- 1%-100% dimmable
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Google Home, Nest
- Wi-Fi
- Body Colour
- Pearl white
- Included Accessories
- Power adapter, LED controller, 2 light strips (1 m)
- UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- Warranty
- 2 years
- 12 mm
- 4 mm
- Length
- 2 m
