No colors or frills, just good old-fashioned illumination at your command. This Wi-Fi smart light is perfect for easy, affordable smart lighting in home or work.
- Unanimously the perfect temperature of white for everywhere
- Control from anywhere using the LIFX cloud technology
- Dim with software and set the mood for any occasion
- Connect your LIFX Mini White with leading connected home devices for further automation
Easy set up
LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. -
Built in Wi-Fi & LIFX Cloud
Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud. -
Adjustable and dimmable
Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room. -
Intuitive control
Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes. -
Bright & efficient
LIFX Mini has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
- LIFX Mini White - LED light bulb - shape: A19 - B22 - 9 W - warm white light - 2700 K - pearl white
- Light Source Type
- LED light bulb
- Pearl white
- Shape
- A19
- Socket Type
- B22
- Wattage
- 9 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 800 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Shape
- A19
- Socket Type
- B22
- Wattage
- 9 W
- F
- Energy Consumption per 1000h
- 9 kWh
- Warm white light
- 2700 K
- Colour Rendering Index
- 80
- Luminous Power
- 800 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- Lifetime
- 22.8 years
- 1%-100% dimmable, Android compatible, iOS compatible, Windows compatible, voice activated, Wi-Fi controlled
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.5 Watt
- Body Colour
- Pearl white
- UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- ENERGY STAR
- Warranty
- 2 years
- Diameter
- 59 mm
- Length
- 105 mm
- 141 g
- Shipping Dimensions (WxDxH) / Weight
- 63 mm x 63 mm x 125 mm / 177 g
