Inspired by the sun, Day & Dusk automation tailors the brightness, color and temperature of your lights to compliment your day with each section of designed to enhance your health and lifestyle.
- Set your wake up time and ease into the morning with soft daylight whites
- During the day, stay active with natural and bright white tones
- As the evening sets in, a calming amber glow will help unwind
- When bedtime comes around, your lights fade to a dim night light or to completely off
Day Dusk settings are completely customizable and designed to function around your day. You can set the routine to run only on the days you want and simply turn off sections that don’t fit in with your schedule. The choice is your
Easy set up
LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go. -
Built in Wi-Fi & LIFX Cloud
Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud. -
Adjustable and dimmable
Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room. -
Intuitive control
Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes. -
Bright & efficient
LIFX Mini Day&Dusk has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
- LIFX Mini Day & Dusk - LED light bulb - shape: A19 - E27 - 9 W - warm white/daylight - 1500-9000 K - pearl white
- Light Source Type
- LED light bulb
- Pearl white
- Shape
- A19
- Socket Type
- E27
- Wattage
- 9 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Warm white/daylight
- Colour Temperature
- 1500-9000 K
- Luminous Power
- 1000 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Shape
- A19
- Socket Type
- E27
- Wattage
- 9 W
- 60 W
- E
- Energy Consumption per 1000h
- 9 kWh
- 1500-9000 K
- Colour Rendering Index
- 80
- Luminous Power
- 1000 lumens
- Beam Angle
- 250 degree(s)
- Dimmable
- Lifetime
- 22.8 years
- 1%-100% dimmable, Android compatible, iOS compatible, Windows Mobile compatible, voice activated, Wi-Fi controlled
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.4 Watt
- Body Colour
- Pearl white
- Package
- Box
- UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
- ENERGY STAR
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 105 mm
- 141 g
