LIFX Mini Day & Dusk Wi-Fi Smart LED Light Bulb E27 - 4 Pack
Quicklinx: DDBBWS00 Mfr#: HB4L3A19MTW08E27
Select:
  • 4x E27
Inspired by the sun, Day & Dusk automation tailors the brightness, color and temperature of your lights to compliment your day with each section of designed to enhance your health and lifestyle.
  • Set your wake up time and ease into the morning with soft daylight whites
  • During the day, stay active with natural and bright white tones
  • As the evening sets in, a calming amber glow will help unwind
  • When bedtime comes around, your lights fade to a dim night light or to completely off
Day Dusk settings are completely customizable and designed to function around your day. You can set the routine to run only on the days you want and simply turn off sections that don’t fit in with your schedule. The choice is your
  • Easy set up
    LIFX screws in like any traditional light bulb. Simply download the app, connect to Wi-Fi and you're ready to go.
  • Built in Wi-Fi & LIFX Cloud
    Offers full lighting control via Wi-Fi with the LIFX iOS, Android and Windows 10 apps. Access your bulbs anywhere, anytime via the cloud.
  • Adjustable and dimmable
    Connected lighting for your space, time of day, and mood. Choose from 16 million colors and a full range of warm to cool white with flexibility to dim. Experience how subtle adjustments in tone and brightness can enhance the comfort of any room.
  • Intuitive control
    Control lights individually or as groups, set timers, pick from beautiful themes or create your own custom scenes.
  • Bright & efficient
    LIFX Mini Day&Dusk has an output of 800 lumens, the equivalent of a 60W traditional incandescent bulb with the benefit of only 9W energy use. Designed for Energy Star.
LIFX Mini Day & Dusk - LED light bulb - shape: A60 - E27 - 9 W - warm white/daylight - 1500-9000 K - pearl white (pack of 4)
Light Source Type
LED light bulb
Packaged Quantity
4 (specifications are for single item)
Pearl white
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
E
Colour of Illumination
Warm white/daylight
Colour Temperature
1500-9000 K
Luminous Power
1000 lumens
Beam Angle
250 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Platform
Apple HomeKit, Google Home
Communications Technology
Wi-Fi
AC 100 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
E
Energy Consumption per 1000h
9 kWh
Warm white/daylight
Colour Temperature
1500-9000 K
Colour Rendering Index
80
Luminous Power
1000 lumens
Beam Angle
250 degree(s)
Dimmable
Lifetime
25000 hours
1%-100% dimmable, Android compatible, iOS compatible, Windows Mobile compatible, voice activated, Wi-Fi controlled
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.4 Watt
Internet of Things (IoT)
Platform
Wi-Fi
Body Colour
Pearl white
Package
Box
UL, cUL, IC, MIC, FCC, R&TTE, RoHS, PSE Mark, REACH, CQC, SAA, SRRC, EAC, RCM, TRA, FAC
ENERGY STAR
Warranty
2 years
Diameter
60 mm
Length
105 mm
141 g
